跳转到主内容
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
25 个问题 查看全部
wires came loose as I was removing battery, how to repair?
I was following instructions to remove the battery from my Flip Mino Hd. I hadnt used in it years and tried all else to turn on an retrive video. Noticed two wires unsoldered from motherboard during the process, one red, one black. The other two remained in tact. Can I solder them back on and if so, how?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@fixerchick those are most likely the power leads from the mic. Post some images of your board so we can see which wires are off. Use this guide 在已经存在的问题里加入图片 for that. It will allow us to see what you see. Of course, you can also take a look at this image
from here Flip MinoHD Battery Replacement to see if that shows the wires you are referring to.
Yes, those can simply be soldered back to the board. Check videos like this one or this one or this guide 如何焊接和拆焊 to get a feel for what you need to do.
Soldering图片
指南
如何焊接和拆焊
难度:
困难
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Flip MinoHD Battery图片
指南
难度:
中等
15 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Celeste Gurney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 182
