跳转到主内容
The Nikon Coolpix S3100 was released February 2011and has a 14.0 megapixels with a wide 5x zoom and 2.7 LCD screen.
8 个问题 查看全部
Why is my camera showing "battery exhausted" after charging
i have replaced the battery ,and after charging the max charge indicated 50% only
and after ipicture taken "battery exhausted" shows.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Are you charging through a computer or with the AC charger?
完成的
a.c. charger
完成的
why is my camra showing Battery exhausted
完成的
The problem with my cool pix aw130 was the little yellow plastic tab that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
完成的
添加一条评论
5个答案
最有帮助的答案
Read this on www.tomsguide.com So make of it what you will.
''try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera. this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.''
Actual Nikon fix
这个答案有帮助吗?
得分 1
3条评论:
I tried the procedure unfortunately it didn't work, thanks though.
完成的
i done as u said and it did not work
完成的
Did not work. Tried times. Disappointing after buying a new battery and they are not cheap.
完成的
添加一条评论
Those batteries are smart with a chip in them. Only allow so many cycles or limit the time used-years.
One of the best cameras for I have for posting on CL with its PC mode low resolution setting
这个答案有帮助吗?
得分 0
添加一条评论
It did not work. Tried it 3 times. Dissapointing especially after buying new battery.
这个答案有帮助吗?
得分 0
添加一条评论
Take the battery out, make sure it's not plugged in and press the on button about 20-30 times. It worked for me. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Text:
Device:
Nikon Coolpix S3000 Camera
Status:
open
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
colin playdon 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 63
总计 13,720
