跳转到主内容
Nissan introduced the sixth generation Sentra at the 2006 North American International Auto Show in January.
11 个问题 查看全部
Stalling after tune up and changing mass air flow sensor
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you replace the MAF with a Nissan part, or an aftermarket one?
完成的
添加一条评论
1个答案
Did you scan your car prior to installing the MAF to make sure that was the actual problem? Or is it was a mechanic did you see the print out? Then after installing the part, did you clear the codes, test drive and check to see if new or same codes came back?
MAF sensors are very fragile, and can be easily damaged during install by being rougher than necessary.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marcus Napoleoni 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 10
过去 30 天: 10
总计 455
