跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
211 个问题 查看全部
Dropped ipad mini 2. Screen looks fine. LCD needs replacing?
Do these kind of accidents usually only require LCD to be replaced? No cracks on the actual screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
what does it look like? I don't know what you are describing. 在已经存在的问题里加入图片
完成的
that was fast.
完成的
添加一条评论
2个答案
已选择的解决方案
Theres screen burns in the top left, so either way you probably need to get it fixed. the weird patterns on it, also probably the LCD.
iPad Mini 2 Wi-Fi版 LCD面板更换
这个答案有帮助吗?
得分 3
5条评论:
Most definitely a damaged LCD, it has to be replaced. The top left is not screen burn though, it's cracked LCD and that is the liquid part of LCD leaking into the surrounding area. Because it is no longer in cells (pixels), it cannot be controlled and is therefore opaque.
完成的
@captainsnowball @refectio Thanks for the info! I will be opening it up tonight. Would the liquid happen to damage anything else? I have a replacement LCD and adhesive strips. Hoping this is all I need for the fix!
完成的
Liquid? you didn't say. yes it will most likely. you need to completely disassemble the device iPad Mini 2 Wi-Fi Logic Board Replacement (this guide almost is complete dissassembly) and clean it in alcohol. Electronics Water Damage
完成的
@captainsnowball not liquid damage but liquid from the damaged Liquid Crystal Display (LCD)!!!! ;-)
@mattmart89 you'll be fine with replacing the LCD according to the guide. No worries about the liquid, it will not go anywhere else.
完成的
@oldturkey03 Thank you for the info! LCD replacement did the trick!
完成的
添加一条评论
if you are able to take the screen off with out damaging it you can get away with only replacing the lcd
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MattMart89 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 81
总计 3,098
