跳转到主内容
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
16 个问题 查看全部
Will parts be same from 1998 4runner to a 2001 4runner
Would a 1998 toyota 4runner front bumper and headlight assembly and bumper fit my 2001 toyota 4runner?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
@natashadianne1 yes it should. If in doubt have either a recycler or the parts store check it in their interchange manual. My manual says that they are the same part numbers.
这个答案有帮助吗?
得分 3
添加一条评论
96-98 are the same other than grill and minor cosmetics. 99-02 are the same other than grill and cosmetics. Headlights are interchangable, but the bumper may not be. The 99 and up have whats sometimes referred to as the "fat lip" bumper and the turn signals are removed from the bumper to below the bumper. As far as bolting and lining up, they should all work...96-02 3rd gen
这个答案有帮助吗?
得分 1
添加一条评论
Will 95 front diff fit on a 98
这个答案有帮助吗?
得分 0
添加一条评论
Yes some enter brackets are different on the side of bumper behind the fenders. They are about a inch shorter than those on a 97 model. They are v shaped brackets
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Natasha D Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 48
总计 3,494
