跳转到主内容
加入维修社区 - 创建账户
HP Compaq DC5700 的维修指南和故障排除信息,这是一款 2007 年推出的商务级台式电脑。
bios corrupted? or other device problem?
Hi Guys! My Desktop Computer Doesn't work, it says "error 162" and need to replace new cmos battery, I'll waited for an half hour to boot but nothing happens. I've also try to reset the battery and jumper cup and nothing happens.. when i press the F10 or F9 on the display options it doesn't work it stuck for an hour and nothing happens. I've also tried to replaced new cmos battery and it doesn't work also... please help guys!!! lets fix the world =)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Go into the bios settings.
Reset to default settings
Make sure your date and time are correct as well.
Save settings and reboot without powering off.
这个答案有帮助吗?
得分 2
4条评论:
Hi S W, i can't even go to Bios. when i press F10 it Stuck.
由完成的
Hi S W, i can't even go to Bios. when i press F10 it Stuck. i let it run for an hour and nothing happens..
由完成的
Are you using a USB keyboard? If so, you need to find and plug in an old PS/2 style plug keyboard. That is the old round type plug you see on the back that is green.
由完成的
I have the same problem here, no mater what kind of keyboard you use, still the same result, changed to new cmos battery but it is stuck , pressing F10 in a sequence of 1 second repeatedly as soon as it is turned on will let me in the language selection part of the bios, but as I select any language, the system reboots.... is there a way to phisicaly change this bios ????
由完成的
添加一条评论
添加你的答案
JoeTech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 1,737
