跳转到主内容
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Green snake charging error problem?
Hi, I have ten into this green snake charging problem on my apple watch and was wondering what to do to repair it or fix the problem?
I have tried unplugging it for 2 days then charging it, that didn't work. If I leave it charging for 2 days still same problem.
Could replacing the battery fix this?
Here is a video of the problem: https://www.dropbox.com/s/q6zg0h13i0shyh...
Thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Anyone know what is going on or how to fix?
完成的
This is a common issue I have been seeing online. No one knows whats going on or how to diagnose?
完成的
添加一条评论
3个答案
已选择的解决方案
I fixed this a couple days ago and the problem was that I needed to replace the battery.
Works great now!
这个答案有帮助吗?
得分 1
1条评论:
How much is it to replace a battery?
完成的
添加一条评论
最有帮助的答案
Try holding both buttons for at least 10 seconds. If no luck, then try a different charger. Maybe more amps. Don’t charge from a computer just in case.
这个答案有帮助吗?
得分 1
添加一条评论
I would like to know if you got it fixed ? And how you did it , i got myself a battery from ifixit and my watch is on the green snake for 2 days and I have left it on the charger since then nothing has changed try hard reset and nothing so please share how tu fix it
这个答案有帮助吗?
得分 0
4条评论:
It was the battery that was the issue.
完成的
Did you have to replace the new battery again? I just got a battery from ifixit, and the same situation.
完成的
I just installed an ifixit replacement battery and now get the green snake. Are the ifixit batteries faulty?
完成的
I'm coming to the conclusion that the batteries sold by iFixit are too old sometimes (especially when they are for the early watch models). I'm having the same prob after installing a new battery. The snake screen should go away after a few minutes of charging but it doesn't.
Edit: After the third try to reset the watch, I finally got to the Apple logo and the battery (almost empty) now charges normally.
Edit 2: Nope, the charge progress vanishes all the time after a few minutes, Trying different outlets/USB sockets now…
Edit 3: After a while without any sign of proper charging, the watch restarts automatically and then starts charging normally. I guess, erratic behavior after installing a new battery which is almost empty is normal. Keep calm and wait patiently. I hope that my replacement battery is better than the old one (it was good to replace it in any case, as the old one just worked for 4 to 8 hours max, but after taking it out of the watch I figured that it had expanded.
完成的
添加一条评论
添加你的答案
Cameron Saman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 16,522
