跳转到主内容
加入维修社区 - 创建账户
诺基亚 3310 于 2000 年发布,以其极为坚固耐用而闻名。
Why do I have no network coverage?
I'm pretty sure the phone is properly unlocked and i put my sim card in and activated it on my cell phone plan and no matter where I go (places where on other phones i get great coverage) i get no signal. Is this an issue with the phone, the carrier, unlocking, or just a bad antenna? what do i do to fix the problem? would i just be better off buying another one since i may have a faulty handset?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi @ncook ,
Do you mean the Nokia 3310 (2017) model or the original 3310?
Have you selected the correct SIM slot for making connections?
完成的
i am talking about the original nokia 3310 that came out in 2000
完成的
@ncook
im not sure this'll be correct but the carrier you are on may or may have not switched off 2G services so that may be it.
完成的
添加一条评论
2个答案
最有帮助的答案
The 2000 Nokia 3310 only has support for 2G bands GSM 900/1800MHz. There is no 3G support.
AT&T has shut down all 2G towers.
Make sure your carrier supports 2G 900/1800 GSM.
The phone will definitely not work on Verizon and Sprint.
这个答案有帮助吗?
得分 5
6条评论:
I am on MetroPCS which I believe is owned by T-Mobile and I thought i heard somewhere that MetroPCS uses their cell towers.
完成的
@ncook MetroPCS is own and operated by T-Mobile. Correct. They only support the 1900mhz frequency. So your phone does not support T-Mobile.
https://en.wikipedia.org/wiki/T-Mobile_U...
If you really like the Nokia 3310, they are making it again. The new one supports T-Mobile/MetroPCS and has a built in FM Radio. The screen is also in color :-)
https://www.ebay.com/itm/263511642450
完成的
ok thank you
just out of curiosity is there any carrier that still does support the OG 3310?
完成的
Yes. https://en.wikipedia.org/wiki/GSM_freque...
Note that due to basic physics, lower frequencies (850mhz/900mhz) travel farther, so those are the frequencies that are used most.
完成的
well if the OG 3310 has a 900mhz band and 900mhz is used the most why doesn't it work
完成的
显示更多的1条评论
添加一条评论
Because the Nokia 3310 runs on 3G service and they took down those towers a long time ago
这个答案有帮助吗?
得分 0
1条评论:
Really not true. The 3310 3G remaster did, but this version runs on 2G TDMA, which is still available although not to new subscribers, sadly.
完成的
添加一条评论
添加你的答案
Noah Cook 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 33
总计 11,289
