跳转到主内容
各种显卡维修指南。
110 个问题 查看全部
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
hmm noone?? :)
完成的
添加一条评论
4个答案
最有帮助的答案
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
这个答案有帮助吗?
得分 2
1条评论:
its not the same
完成的
添加一条评论
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
这个答案有帮助吗?
得分 1
6条评论:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
完成的
i would only be guessing as theres no schematic i would probably try 0603
完成的
most r200 is see are 1w 1% so any resistor around that
完成的
where i can get that...0603 r200? :)
完成的
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
完成的
显示更多的1条评论
添加一条评论
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
这个答案有帮助吗?
得分 0
1条评论:
@hendricorico no, it is not a fuse.
完成的
添加一条评论
@xuw here it is almost 6 years later and I am certain you have replaced your video card by now. Just for completion sake, check the reference designator on the PCB
. It says B200 and MB200, so it is not a resistor. It is a ferrite chip bead inductor. In this case it has a impedance of 220 Ohm 2500mA 25% in a 0603 package
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ole 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 43
总计 3,488
