跳转到主内容
各种显卡维修指南。
97 个问题 查看全部
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
hmm noone?? :)
完成的
添加一条评论
5个答案
最有帮助的答案
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
这个答案有帮助吗?
得分 1
6条评论:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
完成的
i would only be guessing as theres no schematic i would probably try 0603
完成的
most r200 is see are 1w 1% so any resistor around that
完成的
where i can get that...0603 r200? :)
完成的
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
完成的
显示更多的1条评论
添加一条评论
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
这个答案有帮助吗?
得分 1
添加一条评论
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
这个答案有帮助吗?
得分 0
添加一条评论
Just for completion sake. Reference designator R200 is a 20Kohm 5% resistor in what looks to be a 0603 package
这个答案有帮助吗?
得分 0
添加一条评论
I have broken RX570 4GB (ROG-STRIX-RX570-O4G-GAMMING)
4 pcs. Resistors 2.2 ohm near PU800 (7805) linear regulator for 5V is extensive heating, on picture I write resistance and voltage
I do not have expirience to fix this RX card, before i fixed older types cards like (GTX 660, R9 280X, …)
If you can help me please….
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ole 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 19
过去 30 天: 66
总计 3,136
