跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy J3 智能手机维修指南。
IMS service has stopped
I get this message when I turn on my smartphone, What does this mean and how can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
IMS stoppage only seems to affect Word and Exel programs. Cleared cache/partition and still get the message on boot.
完成的
添加一条评论
6个答案
已选择的解决方案
See this thread
IMS Service has stopped
这个答案有帮助吗?
得分 14
2条评论:
Tried this on my J3 didn't work. When I rebooted got the IMS service stopped message right away.
完成的
Went to about email, clicked return to factory settings, rebooted, re-entered email account, restarted. Seems to have solved the problem after 5 reboots just to see if it was solved.
完成的
添加一条评论
Happening on my Note8 also! Its constant, making the phone nearly unusable. Seems to be since some updates done automatically during the night. I dont see others complaining of this on other carriers though, seems to be a TMobile issue.
这个答案有帮助吗?
得分 0
7条评论:
I have a Samsung j3 and it is saying this
完成的
Mine just started saying this like an hour ago I have a j3 prime also
完成的
It is happening to me as well and I have the Samsung J3 also.Did anyone find out what the problem is?
完成的
I had this problem and it's very frustrating it means your memory in your messages are full. but all you have to do is clear all old text msgs and the problem is fixed. Just did it and its back to normal I have a Samsung J7
完成的
Thanx Anil. They say to go the cheapest, easiest way first and in my case it worked on my Samsung Galaxy j3 2016.
完成的
显示更多的2条评论
添加一条评论
This just happened to my note 8 and within a week it happened to my wife's. So the fix is actually pretty easy. But is annoying that you have to go to the TMobile store and get your sim card replaced. After it's replaced, power off your device and press the volume up, bixby button and power button at the same time. Once the blue screen appears (with Android) during bootup you can release all 3 buttons and wait. Once you get to your bios screen. Scroll down to clear cache with volume down button. Select it with the power button. (Warning be sure your selecting clear cache! Not resetting your device! They are right next to each other) After your given the option to reboot. Select that option and the evil message IMS Service has stopped should not come back! Hope this actually helps everyone save some time! (This is my experience from over 45 minutes on the phone with tier 2 tech support, 2 phone calls and a visit to the TMobile store. Also the tier 2 rep said they'd credit my account for the sim card. The employee at the store didn't charge me for it. Just FYI
这个答案有帮助吗?
得分 0
添加一条评论
I uninstalled the last app I downloaded, which for me was Instagram. I restarted in safe mode. It popped up once then not again. My messages started working again.
这个答案有帮助吗?
得分 0
2条评论:
I just force stopped the IMS service on my Note 8. It's worked so far.
完成的
I went to general maintenance, rest, reset network settings and it fixed it
完成的
添加一条评论
Where can I find my IMS under my setting on the galaxy j3? I don't see the initial IMS under my app. Please help!
这个答案有帮助吗?
得分 0
添加一条评论
After updating to new software version for my note 8
I got error “ IMS service keeps stopping “ and its super slow every few seconds this error keeps popping up
This is a disaster after doing an update pls help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Salter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 36
总计 63,390
