跳转到主内容
In North America, the RX 330 series began sales in March 2003 for the 2004 model year.
2 个问题 查看全部
Why does my Lexus Rx 330 shake
I have 2004 Lexus Rx 330 when I am driving over 40 miles an hour then apply the brakes my car shakes I know its not the breaks they have recently been changed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi @iammldqueen ,
If it only happens when the brakes are applied, get the brakes checked. It may be that one is "grabbing" when being applied.
Does your steering wheel shudder when this happens? If it does it may be one of the front brakes that is the problem.
完成的
添加一条评论
6个答案
最有帮助的答案
@iammldqueen check your tires for wear and have your tires rotated and balanced.
Update (02/18/2018)
@iammldqueen " you mentioned that "I know its not the breaks they have recently been changed" if it is just the pads that got changed then you'll have to check the rotor and calipers. Hopefully whoever fixed your brakes did that. Go with the tires first.
这个答案有帮助吗?
得分 2
2条评论:
I have brand new tires less than 3 months ago
完成的
Although the tires are new, it could happen still. Also, most tire centers recommend revisiting them within a few weeks to make sure the bolts are properly tightened. I would also still follow @oldturkey03 suggestion along with the alignment.
完成的
添加一条评论
@iammldqueen
1. Do wheel balancing.
2. If that didn't help - check the calliper pins, make sure they are not bent (even slight bent will cause a problem).
I had a case when some stupid mechanic over-tightened them up to bending them. I had uneven break pads wear on rear, that also was partially locking disk breaks, wearing them off, increased petrol consumption, annoying sound, overheating...etc. In case of front wheels you'll get vibration. Considering you've changed break pads recently - this might be the exact problem.
3. If that doesn't help - your break disks overheated at some point and if they are not so flat anymore - one more reason for vibration.
这个答案有帮助吗?
得分 1
1条评论:
Process of elimination, did you have the issue before brake work? If no AND you haven't warped your front rotors due to hard braking, take it back to mechanic who did work. If rotors are new, could be a defective rotor. So, it's really dependent on extent of work and how thorough it was done.
完成的
添加一条评论
if youve had the brakes recently changed, bring it back to who did them for you.
if they didnt set the new rotors and pads your rotors could be warped. but like i said before if you took it to a store \ shop to do it and this is a result of that bring the car back to them. or call them and ask if theres anything that could be done.
这个答案有帮助吗?
得分 1
添加一条评论
Change rotors and break pads you'll be just fine.
这个答案有帮助吗?
得分 0
添加一条评论
Tire misalignment, and or just bad tires. Check tire pressure and tire threads.
这个答案有帮助吗?
得分 0
添加一条评论
Because no break pad
Update (08/14/23)
You have you check your wheel balance or tire pressure
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
B Perry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 3,731
