跳转到主内容
加入维修社区 - 创建账户
Dell Alienware M17x R2 电脑的维修信息和故障排除。该设备是 Dell M17x 游戏笔记本电脑的第二个版本。
How do I replace the thermal paste on the gpu.
I took my gpu out of my pc but I don't know how to safely get to the compound.
Update (02/12/2018)
this is the gpu I need to repaste
Update (02/12/2018)
gpu
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@samadam It appears all you need to do is unscrew the screws around the heatsink that attach to the clamp on the other side. It looks like a philips.
I've updated my answer.
由完成的
添加一条评论
2个答案
最有帮助的答案
This may be what you're looking for: 如何涂散热膏
Update (02/12/2018)
Unscrew these screws:
And it should come off. Be sure to clean and reapply thermal paste to mating surfaces when done.
这个答案有帮助吗?
得分 3
2条评论:
Not quite what im looking for ,thank you. Is there a way for me too send you a picture of my gpu. It has a x like clamp on it that I assume the paste is under but I don't know how to safely remove it. It kinda looks like the clamp on a Xbox one gpu.
由完成的
@samadam, use this: document
Pages 85 and up I believe.
由完成的
添加一条评论
Flat head screwdriver if it's like the Xbox. Then u can get thermal paste cleaner and thermal paste online. A plastic razor blade (similar to the red kind used on lcd displays) should easily remove the paste.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samadam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 857
