I get a message "prime" what does that mean?
After brewing a couple of cups, I get a message that says "Prime" the machine will not work unless I unplug and re-plug. What do I need to do to keep that from coming up?
James young it is possible that you get the Prime message because the water does not drain from the reservoir. Your reservoir has a filter in the bottom which may be dirty, or your needles are clogged. there could be debris clogging the needle. Use this guide 如何打开和清洁Keurig咖啡机 to work on that. Let us know what you find after.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 51
过去 30 天: 283
总计 3,690
