跳转到主内容
The eighth generation of the Mitsubishi Lancer.
50 个问题 查看全部
When driving and heading to stop the engine fluctuates also P0507 code
P0507 code, and engine fluctuates when slowing down. Acceleration is rough, I’ve cleaned out the mass a flow sensor as well as the IAC, and throttle body. Still having same issue. Was thinking of replacing some of these parts but wanted to know what your suggestions were.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The PCM has determined that the engine RPM is higher than expected fro the current engine operation conditions"..
-Probable Causes
1. Vacuum leak on engine
2. Dirty TB
3. IAC motor defective
4. Poor electrical connection to the IAC valve
Test for vacuum leaks with a can of carb cleaner. If the idle increases while you are spraying on the vacuum lines and connectors you know it leaks. Replace your lines.
Also try to reset you ECU by removing the positive cable from your battery and leave it disconnect for 15-30 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Craig Rasco 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 343
