跳转到主内容
加入维修社区 - 创建账户
为各种电视(TV)品牌和样式提供指南和支持。
Disassemble TV Image problem
A TV image is clear and becomes distorted The capacitors look intact And also sound electronic boards
Mise à jour (06/02/2018)
board t-con Sounds good As well cables ribbon
where is the problem
Update (02/08/2018)
liquid in that arrow
I thought it existed from a factory
Shall I wipe it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@medjdoub45,
If your television has image distortion issues, see the Insignia NS-24ER310NA17 Has Image Distortion problem page for possible causes and solutions.
Your images a bit fuzzy but it appears that this is happening to the right half of your screen. That could an issue with your t-com board or your panel. The t-con board is the one under the metal cover that has the two cables going to the panel.
Update (02/08/2018)
Your last posted image does not look like liquid but it looks like an overheated IC. Replace the T-con board and re-evaluate.
这个答案有帮助吗?
得分 1
2条评论:
Looks like it's not an board t con
完成的
@medjdoub45 did you try a new board?
完成的
添加一条评论
添加你的答案
medjdoub guerine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 263
