跳转到主内容
加入维修社区 - 创建账户
JBL Flip 4 便携式扬声器。这是一款获得 2017 年 CES 创新奖的 IPX7 级防水蓝牙双驱动单元扬声器。
Connect + no longer opening since iOS update
For some reason ever since the update to iOS 11.2.5, my JBL Connect + app (that previously worked fine) no longer works. It now starts on a screen that directs me to turn on the Bluetooth on my iPhone X, despite it already being turned on and paired with the speaker.
No matter which order I do things in (I’ve tried turning off Bluetooth and then starting it when the Connect + app asks for it, but it still doesn’t think I have Bluetooth turned on).
I’ve tried restarting my phone, telling it to forget the speaker(s), resetting the speakers to their factory settings etc. No dice.
The main issue I have is that I use two Flip 4’s for the stereo feature but I can’t turn that on unless I can access the app.
Can anyone help or has anyone else had problems since the iOS update??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If your JBL Flip 4 speaker refuses to connect to another device through Bluetooth, see the JBL Flip 4 Won’t Connect Through Bluetooth problem page for possible causes and solutions.
Try:
a) first uninstall the app
b) go to Settings --> General --> Reset Network Settings
c) completely power the phone off after it resets and reboots
d) download the app again, and try pairing blu tooth from scratch.
这个答案有帮助吗?
得分 3
3条评论:
Sorry for taking so long to respond but your solution totally solved my problem. Thank you so much for taking the time to help out. I really very sincerely appreciate it.
由完成的
worked for me too, thanks
由完成的
Perfect , but restarting after reseting was for my iPhone X and charge 4 not necessary
由完成的
添加一条评论
添加你的答案
Max F 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 21,042
