跳转到主内容
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
How can the optical sound output be connected to RCA amplifier?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Here's a good vid on how its done and what you'll need: Digital to Analog Audio Converter Optical / Coaxial / USB. There are many suppliers besides this company.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi,
Here is an image which shows how to connect an optical cable between the TV and the RCA amp, if it has an optical input that is. You didn't give the model number of the amp.
(click on image to enlarge for better viewing).
If you wish to mute the audio from the TV speakers when you have connected the TV to the amp go to Menu > Sound > TV speakerand select Off. If you leave it set to On you will have audio from both the TV speakers and the amp.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Vives Llor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,417
