跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
256 个问题 查看全部
LEFT and RIGHT next to the display - the bottom is not fixed properly
Hi Guys,
I just bought a new customized MacBook Pro 13" with Touch Bar...
I have a brief question - I recognized that the bottom plate of the MacBook does not fit perfect left and right next to the display mounting. Its a bit uneven and can be pressed in. Additionally its sharper then on other MacBooks....
Has anyone experience with it? Is it somehow bad? - I used to go to the apple store and they just said that its probably not fixable. They offered me to refund me but that would mean 2 Weeks with our a macbook...
Thanks in advance for your thoughts!
Cheers
Philip
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
If you just bought it you should get it fixed under warranty! I would go to an Apple Store to have them look at it and if need be get a replacement system. It shouldn't take more than a week.
完成的
the point is, that I am doing my study abroad semester at the moment and its a bit complicated to do this replacement in another country...
But still I would be just interested what this could be...
完成的
What country are in in?
完成的
I just uploaded two pictures... I bought the Macbook in Germany and now I am in UK
完成的
添加一条评论
1个答案
已选择的解决方案
The images look like the center clips didn't get set which is why the center is bowed out.
While this is the Function Key model, the lid is taken off in the same way: 2016末期13寸 MacBook Pro 功能键版本的底壳更换.
But before you open your system I would strongly recommend you visit an Apple Store in the UK. Technically 'Apple Europe' includes Germany so I don't see why they would give you a hard time. It would be different if you came here in the US. They should be able to reseat the bottom cover.
If you damaged the system or tried to open it you could find your self without coverage.
这个答案有帮助吗?
得分 2
5条评论:
Hi Dan!
thanks a lot for your answer! I think I just go again to apple and ask them to try exactly that...
Thanks a lot!
I will report :-)
完成的
meanwhile....
apple tried to repair it - same problem - They ordered a new bottom case to replace it. So I went again to the store. After replacing the original bottom with a new one its even worse...
Apple now offers me to replace it which seems to be impossible because I bought it in Germany...
完成的
If they offered take it! Don't be so worried about the German issue unless you need a German keyboard.
完成的
the UK store would take it back but they can't because it was bought in Germany with €... Cross border is not possible - this is what they say...
完成的
Only hope then is to ship it to Apple in Germany.
Euro's are still accepted in the UK so I can't see why that matters. Is the issue the exchange rate?
完成的
添加一条评论
添加你的答案
Philip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 121
