跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Broken screen. Can not use touchscreen
I dropped my S8. The part where screen is broken still works. But, the rest of the screen, does not work. Therefore, I can't even turn phone off. And, I can't transfer pictures without touching the allow button. It won't let me. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
最有帮助的答案
It's probably a little late, but I used Google voice to do things for me when my phone stopped letting me touch the screen. It allowed me to do many things, if you know the lingo it helps a lot. I just said "ok google (...)" with what I needed to get done on my phone before getting a replacement.
这个答案有帮助吗?
得分 1
添加一条评论
I was able to connect a logitech M557 Bluetooth mouse
这个答案有帮助吗?
得分 1
1条评论:
How did you do that? I want to use it as a dex with a qi charger.
完成的
添加一条评论
Laura Rogers the only way to fix this is by replacing the display assembly. Use this guide 三星 盖乐世 S8 显示屏更换 for that
这个答案有帮助吗?
得分 0
添加一条评论
You can definitely replace the Glass and LCD with just the glass and LCD, but for ease of repair, may I suggest buying the glass and LCD with the midframe attached. It has a much better end result in how the repair appears cosmetically.
If you're not feeling that risky, look for your local Ubreakifix. Ubreakifix has a partnership with Samsung with OEM quality parts and prices lower than the part is usually listed online.
这个答案有帮助吗?
得分 0
1条评论:
I had this put 7Juuu
完成的
添加一条评论
Try changing the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Laura Rogers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 22,693
