跳转到主内容
加入维修社区 - 创建账户
Dyson V6 Absolute 是一款于 2014 年 9 月发布的无线、无尘袋吸尘器,带有可捕获过敏原的 HEPA 过滤系统。它适用于所有地板类型,重量为 5 磅。型号为 SV09。
Why did the machine stop working?
Stopped working - when I depress the trigger red lights blink. It has been charging so I do not think it could be out of charge>
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your Dyson v6 Absolute vacuum cleaner no longer turns on, see the Dyson v6 Absolute Won’t Turn On problem page for possible causes and solutions.
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
If your Dyson v6 Absolute vacuum cleaner’s battery life is not long enough to complete a vacuuming task, see the Dyson v6 Absolute Battery Life Is Too Short problem page for possible causes and solutions.
The flashing red light means that there is a hardware failure in the device. You would need a technician to troubleshoot the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Wise 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 2,462
