跳转到主内容
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Do you have a working desktop PC? So you could test the disk.
完成的
i have but im not sure if it has internal hdd
完成的
How did it break? did you drop it? spill something on it?
完成的
i installed updates and the system crashed
完成的
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
这个答案有帮助吗?
得分 1
2条评论:
does it have hdd though?
完成的
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
完成的
添加一条评论
添加你的答案
Tomasz Kowalski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 429
