跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 个问题 查看全部
The back light in the Tv is out
I know there is a picture on the screen because I get sound and sometimes a backlight picture. However I can’t get the back light to come on sometimes and right now it’s been weeks since it came on and I get sound whenever I turn it on. Does anyone have the Schematics for a M470VSE VISIO TV SCREEN?! Trying to fix it myself
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@mtl4255 this could be an issue with your power board/LED driver or the backlight array. Remove the back of your set and post some pictures of all of your boards with your question. Let's see if we can identify some components on the boards that may have failed. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 1
添加一条评论
Unfortunately there isn't much that can be done to repair a back light as the display is micro-soldered, and very difficult to repair.
这个答案有帮助吗?
得分 0
1条评论:
@robialecm your answer is a bit off. The display is not micro-soldered and the backlight is separate from the display.
完成的
添加一条评论
添加你的答案
Micah Leonard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 6,819
