跳转到主内容
Nintendo Switch Joy-Con 控制器的维修指南和信息。
Joy con analog stick
My Left Joy-con analog stick is ghosting me forward. It physically works fine, but even after resetting the device and re-configuring the controller it still stays the same. Any tips on how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
最有帮助的答案
@tigerjoshy you probably already solved your joystick problem, but for anyone else who comes across this question: this is now a widespread issue that has been acknowledged by Nintendo! You can contact them for a (potentially free) repair, or check out our left and right joystick replacement guides and our replacement joystick part.
Replace a Nintendo Switch joystick on the left or right Joycon controller.图片
产品
Nintendo Switch Joy-Con/Switch Lite Joystick
$14.99
Joy-Con 左侧摇杆图片
指南
Joy-Con 左侧摇杆更换
难度:
中等
30 minutes
Joy-Con 右侧摇杆图片
指南
更换右侧Joy-Con摇杆
难度:
中等
30 minutes
这个答案有帮助吗?
得分 1
添加一条评论
Hey! I’ve had this problem and I’m happy to help! There’s two things you can do. You can get a new toothbrush and brush under the analog stick, doing this will remove any dust! If that doesn’t work contact Nintendo, if the joycons came with the console, and it’s been under a year since you’ve purchased the switch. You can call Nintendo, set up a repair, and they can repair it for you! (If you bought them separately you need to have your receipt for proof of purchase!) However you can also ask them to replace the joycon instead, so instead of fixing the old one, they just send you a new one! Hope this helps!!
这个答案有帮助吗?
得分 0
1条评论:
I tried the toothbrush. It didn't work, in fact I think it made it worse
完成的
添加一条评论
添加你的答案
Joshua ovalle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 10,017
