跳转到主内容
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 个问题 查看全部
Ive dropped my phone in water, everything works but the on/off button
I dropped my phone in water and immediately took steps to dry it, after a small amount of time, I powered it back on and everything seemed to work except the power button. I can still turn it on because of the home button but it only turns off on time-out. Looking for a solution to this problem. Any help is appreciated.
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
redbubba02 besides the great answer by @j0vian I suggest that first you do not turn on your phone, charge it or try to connect it in any way. Remove the battery from the phone to minimize further damage. After that completely disassemble your phone by using these guides. Using 90%+ isopropyl alcohol, clean your phone by following this guide. It was written for an iPhone but all the points still apply to your phone as well. While cleaning, check for obvious missing or damaged components. you can always post some images of your boards etc. with your question so we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. Once it is properly cleaned, replace the battery and reassemble your phone. Only after it has been fully cleaned can you properly troubleshoot. Liquid damage is the hardest to troubleshoot and the most difficult to repair since virtually any part/ component may be involved. Your could simply be a shortened power button but it could as well be a failed component on the power circuit.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 3
2条评论:
@oldturkey03 ahh shucks.... thanks and have a happy new year and quit playing on the computer. :-) You should be having fun...
完成的
@j0vian you are right brother. Wishing you and yours a Happy New Year!
完成的
添加一条评论
The steps to a water damaged device it to fully disassemble it and clean the board with 92% rubbing alcohol and a toothbrush. if the device is powered on before all moisture has been removed then parts may have to be replaced. But the funny thing with liquid damage is that it can do very funny things afterwards if not immediately then later on.
这个答案有帮助吗?
得分 2
添加一条评论
Everytime I tried to turn my phone off it not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
redbubba02 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 44
总计 2,363
