跳转到主内容
Repair information for standalone freezers.
192 个问题 查看全部
Which thermostat should I buy and how to wire it?
So I have a freezer with a bad thermostat (the contact wont close when it gets hot unless I hit it)
the thing is the thermostat has 4 pins
It works like this
The green light is always on
The red light turns on if the temperature is too high to safely store food
And the yellow light turns on when you hit the fast freeze button(which based on the wiring it just bypasses the thermostat)
I already bought a thermostat and it works but the upper temperature (when the compressor kicks in) is too high and everything melts and after reading the box it says its for 2 door fridges (its a danfoss thermostat)
The issue I have is that I don't know what type of thermostat I should buy and how to wire it back?
Ive checked on Danfoss website and there are many types and models of thermostats (freezer without signal, freezer with signal and freezer with passive signal or something like that)
Any help would be appreciated
The Freezer in question is an electrolux EFUP195YSKG (220 volt version)
This is the wiring diagram and a pic of the thermostat
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
How about the make and model number of your appliance?
完成的
its an electrolux efup195yskg
220V-50Hz version
完成的
添加一条评论
1个答案
最有帮助的答案
@drasp I'd stick with an FSTB thermostat of the KX series. Check for the specs on here and as you can see some of those are adjustable for the right temps.
The Danfoss Thermostat Part Number 077B7006 has the functions as you described so it may fit as well.
这个答案有帮助吗?
得分 1
1条评论:
Thank you
Now I have to see if someone sells it
完成的
添加一条评论
添加你的答案
ahjklsf 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 1,504
