跳转到主内容
加入维修社区 - 创建账户
Xbox One S 是微软于2016年8月推出的电视游戏主机。它是 Xbox One 的改款升级机型。
Wet Xbox need help
How would I fix on Xbox one s with water damage
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
I have Coca-Cola in my Xbox one s was cleaning in I hit my cup by accident
由完成的 分享
So......just for clearing my mind, I came home the other night and found my Xbox 1s (white -- pre-1x) with at least 1 1/2 c of water in it. Is this something that could happen from a water-cooled system? Or should I look into malicious intent?
由完成的 分享
My problem is mi little kid drop water in Xbox one s I try to dry the Xbox. Everything seems ok, but when go on the Xbox turn off. My friend say is the power supply, but when I open the Xbox the water go in the fan, so my question is. Is possible the fan get wet, the system is not go on?
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
Hi @acgrieve32 ,
You would need to completely dis-assemble the XBox and use IPA 99%+ to clean away all the traces of moisture and corrosion. (IPA - Isopropyl Alcohol - available at electronics parts stores. Try not to use 'rubbing alcohol' as this is sometimes <70% IPA , can sometimes contain additives and is not as effective. Check the label if you do decide to use it.
Here is a link to the ifixit Xbox One S repair guides which should be of some help.
Here is a link that in general describes what to do to try and recover a device which has had water damage.
Electronics Water Damage
Hopefully this is of some help
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
NOT RECOMMENDED
Xbox One has internal power supply that accepts utility voltage. One mishap and you electrocute yourself.
If you do want to try, replace the power supply altogether, then think about the board repair thing.
Oh also the disc drive is gone for sure if the mechanical parts are wet, you can only replace the mechanical assembly of the drive, do not replace the drive controller board.
这个答案有帮助吗?
得分 2
2条评论:
What if it don’t work when you fix it
由完成的 分享
consider it lost
由完成的 分享
添加一条评论
Hi i recently came with my little son's xbox 360 completly wet inside, when i picked it up it was like a quarter glass of water in it, i suspect that his little Sister playing drop water on it, anyways y dissasamble completly the xbox and took only the motherboard, y put to dry everything else with towells and stuff, well took the MB and cleaned it first with Hot watter, to take off every trace of the liquid my little doughter drop on it, then i rinde it with alcohol to renové most of the watter i used before, once i got all this done, i took a hair dryer and started to eliminarse all of the moisture left, like 10 to 15 min of that, i look very close to see if there was any more liquids on it, once satisfied with work i put thermal paste on the chip, put everything in its place and give it a try, it worked like a charm, before that it doesn't even turn on so i can say that i brought it to life again hahaha, i can suggest that you could do the same, but carefull with the internal power supply of the xbox one s, you should try to open it too and see if there is no moisture on it, if it so, try to do the same to the PS Mobo. Hope i help someone!
这个答案有帮助吗?
得分 1
1条评论:
It actually worked thank you
由完成的 分享
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 24,398
