跳转到主内容
Repair and support for ceiling-mounted bladed fans.
20 个问题 查看全部
Ceiling fan not responding to remote control
Grandson played with remote control, with a finger on each of the hi & low speed buttons simulataneously, jiggling them. Fan now only runs at high speed & does not respond to medium or low speed buttons. Have replaced battery.
Update (12/26/2017)
The make is Lucci air On the back of the remote is the number FCCID CHQ 70307
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
where is the controller?
完成的
The fan stopped working despite completely working remote and fan able to respond with the main switch
完成的
@aryaan
What is the make and model number of the fan?
完成的
添加一条评论
3个答案
已选择的解决方案
Have a look on the control for a reset switch (hole). If present reset controller. Otherwise post make and I'm sure someone will know if there is a button code to use.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi @chandrakathy,
Mostly the controller (receiver) is located in the housing of the ceiling fan.
Disconnect the power for the fan by removing the fuse in the power box and then access the ceiling fan housing.
Be safety aware you will be working with lethal voltage circuits! If there is no separate fuse marked for the fan then perhaps it is connected in with the lights fuse. If the fan was not working at all so that you can’t verify that it has no power connected by trying to turn it on and off after having removed the fuse, then take no chances and operate the house main power isolating switch or remove all the main household side power and light supply fuses in the power box. If in any doubt contact an electrician. It’s not worth doing it yourself, your life is worth more.
You don’t state the make and model but there are normally some screws that can be undone to access the wiring etc.
Here’s the ifixit Ceiling Fan Light Fixture Replacement guide.
The images shown at Step.2 in the guide (hover mouse over right side image) give you a rough idea where to look for the controller.
这个答案有帮助吗?
得分 1
添加一条评论
If your ceiling fan has stopped working, there are a few possible reasons why. First, check to make sure that the power is turned on at the circuit breaker. If the power is off, flip the breaker switch to the on position and see if the fan starts working. If the power is on and the fan still isn't working, it's likely that a fuse has blown or there is a loose wire. Check the fuse box and replace any blown fuses. If there are loose wires, tighten them with a screwdriver. If none of these solutions work, you may need to call an electrician. learn more ceiling fan solutions here
这个答案有帮助吗?
得分 0
1条评论:
My fan is not working
完成的
添加一条评论
添加你的答案
Carmen 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 119
过去 30 天: 414
总计 42,410
