Almost every game is lagging
I already asked in here,my warranty is US only . My parents bought me from there (I live in india). Can anyone tell me how to fix it.>?
I would try replacing the heatsink and thermal paste. It is possible to have a leaking heatsink. While you have it apart clean the fans out real good.
这个答案有帮助吗?
I will try to replace the heatsink and thermal paste.thanks
Hi,
sorry for the late answer. I have the same laptop and have experienced much better cooling/heat-performance so that the laptop no longer throttles during gaming by doing the following:
Turning off CPU turbo and under-volting CPU/GPU is the least work and have big impact on heat-development.
The following thread has more good information on all the steps mentioned above:
这个答案有帮助吗?
Hi,
https://rog.asus.com/forum/showthread.ph...
Hope this helps,
Hans
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 3,529
2条评论
Post your CPU and GPU temps.
由 TCRS Circuit 完成的
GPU-
Before Lag: https://drive.google.com/file/d/1eob5g9X...
After Lag: https://drive.google.com/file/d/15VtBYAm...
GPU-Z Shows Temperature Max : 97 degree celcius
Minimum 59 degree celcius current idle its 67 degree celcius
CPU -
Intel XTU cpu stress test - i saw two times thermal throttling come up in 5 minutes of stress test , max core frequency came down from 1.80 ghz to 0.80 ghz .cpu stress test passed. Max temp was 77 degree celcius , minimum temp was 60 degree celcius..during the whole stress test was fluctuating betwenn 72 - 75
Update : Ran a stress test on kombustor - GPU was running fine then temp went upto 81 degree celcius and fps decreased from 72 to 24 .. but throttling decreased temperature to 76 degree celcius. same with cpu went upto 80 celcius and dropped from 30 fpss to 10 fps and decrease in temperature
由 Thanics 完成的
