跳转到主内容
加入维修社区 - 创建账户
1999 年发布,初代 PowerMac G3 的继任机型,主频 300-450 MHz,配备 64 或 128 MB 内存,6 或 12 GB 硬盘
Can only get it to boot from disk
After a long, confusing fiasco trying to reinstall the OS on it, replacing cables, swapping out disk drives, amongst other things, I FINALLY got something other than the blinking question mark folder. (which was quite a feat for someone who knows nothing about mac's albeit a fair bit about pc's) Only problem is that I forgot that I had unplugged the HD trying to get it to boot at all. So I plugged the HD back in and all I get now is a blank white screen and no activity from the dvd drive. I tried reformatting one of my pc HD's with macdrive 8 and tried again but I get the same blank white screen. Any help, thoughts or suggestions would be very greatly appreciated, I've been on a mission trying to get my antique up and running and have come so far....I can feel I'm so close!! Please help???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Possible ID conflict. Look up the jumper setting on your hard drive by doing a search for it at the manufacturers web site. If using two hard drives set one to master and one to slave. With just one hard drive you can use cable select but I prefer setting it to master. Fix the hard drive first and then connect the optical drive. The optical drives also have jumper settings. Check the ribbon cable into the logic board as that sometimes gets pulled out some when working on the hard drives.
这个答案有帮助吗?
得分 3
2条评论:
tried that, everything is set correctly
由完成的
Boot up from your system installation disk by holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk Utility and format the drive. and give it one partition. If the drive is an old one I would select the "write zeros" option to map out any bad blocks. This takes a while but will eliminate future problems. Now install your system.
由完成的
添加一条评论
添加你的答案
Cera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 884
