跳转到主内容
**Missing components on logic Board** need help please!
I bought a Macbook Pro 13 inch wich isn't charging and the green Led does not turn on as well. I'm not sure which model it is, on the logic board it says EMC No: 2326. It has a 2.26/3M/1066 Processor and Thunderbolt as well
After taking it apart i noticed that there are components (i think resistors?) missing on the logic board. Is there somebody who can help me identify these?
I added two pictures so you maybe somebody could look up in the scematics
Sorry my english is not the best but i hope somebody can understand me :-)
EDIT: I just found this in the main case, near the area. The other one is still missing
EDIT: MISSING PARTS FOUND!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@swarl3s Don't worry about your language issues! it's fine!
完成的
添加一条评论
4个答案
已选择的解决方案
Parts found:
The big one is a 2.2uF 100V capacitor for the lcd backlight. The other one is a 2.0k ohm pull up resistor for the smc<>charger circuit data line.
Thanks to TCRS Circuit & oldturkey03!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Those are capacitors for backlight. You dont need a new board just find someone who does board repair
这个答案有帮助吗?
得分 3
4条评论:
@tcrs_circuit thanks for your help! I don't think that these parts are just for the backlight. Cause the macbook does not turn on at all, it's not even charging.. I heard something about the one wire circuit wich could be part of the problem? Maybe you know more about that?
完成的
The big capacitor is for back light. No green light not charging is another issue and may be that smaller component that is knocked off but may also be an issue with the charge controller
完成的
@tcrs_circuit The smaller component seems to be a 2.0k ohm pull up resistor for the smc<>charger data line. Thats why there is no green/red light on the charging port! I added two picures
I ordered these parts online and hope they will solve my problem
完成的
yea r6929 is a 2.0k resistor 402 package
完成的
添加一条评论
@swarl3s just to reiterate what @tcrs_circuit has already mentioned. The part that is missing from your board is reference designator C9799 which is a 2.2UF 100V 10% capacitor in a 1210 package. It is part of your backlight circuit.
The issues you are describing are not related to that capacitor.
这个答案有帮助吗?
得分 2
1条评论:
@oldturkey03 thanks for your help! Seems like the other, smaller, component missing is the 2.0k ohm pull up resistor for the smc<>charger data line. I ordered a new one online, hoping it will solve my problem. I added two picture
完成的
添加一条评论
MacBook Pro 13" Unibody (Mid 2009) 2.26 GHz Logic Board
Replace a 2.26 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot. Fix processing issues like unexpected shutdowns, reboots, or water damage.图片
产品
$99.99
这个答案有帮助吗?
得分 1
2条评论:
@mayer thanks for your reply.
Well i hoped that somebody could tell me the exact part number of these two missing resistors. A new logic board would be an easy solution, but the most expensive as well!
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 557
