跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone。维修过程简单直接,但前面玻璃和 LCD 必须作为整体单元更换。GSM / 8、16 或 32 GB 容量 / 型号 A1332 / 黑色和白色。本页面旨在帮助用户对 iPhone 4 进行故障排除、维修和寻求帮助。
Back panel will not slide back on?
I followed the guides within here to take apart my iPhone 4. And made sure to follow and remember every screw I took out, etc. My question is, whenever I go back to slide the back cover back on...it will not fully slide down into position for the two holes to screw it in place...it seems to be "stuck"... any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
you need to put a little bit of force, and check out the outter frame that it is aligned with the housing as u slide it on. :)
这个答案有帮助吗?
得分 5
3条评论:
Thankyou! Put a little more force on it, and bingo, "clicked" right into place no problem. Thanks! :)
完成的
Please "accept" an answer if it solved your problem so that it can be archived for others to learn from. Thanks
完成的
You guys helped me out too! I thought I was going to have to reassemple everything. Then I was scared to apply more pressure. Thanks Guys! Who needs apple care?! IFIXIT!
完成的
添加一条评论
This has happened to me a lot and i have found that the reason being, for me at least, is that i forget to make sure the 6 side screws (with washers) aren't tighten all the way. After i retighten those it fits like a charm!
这个答案有帮助吗?
得分 1
添加一条评论
I just broke the !@#$ out of hte back of my iphone doing htis
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 9,547
