跳转到主内容
Single function HP Officejet printer introduced in 2015.
2 个问题 查看全部
How do I made a hard reset of this printer?
I've seen searching and there's no info about it. Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
4条评论
The explanation isn't helpful. I can't find the Cancel or Wireless button on my HP 6978
完成的
my problem is the same as above (stanpioro). Also can't login to post my question. Doesn't accept my email and password.
完成的
all printers have a small battery Its hidden as they don´t want you to find it...
If you take it of for 20 seconds all software problems are gone...
完成的
@macgyver2
Where?
完成的
添加一条评论
2个答案
已选择的解决方案
Hi Ignacio,
Google search:
Type “manual HP Officejet Pro 6230 printer”
Result:
http://h10032.www1.hp.com/ctg/Manual/c04...
“Overview of buttons and lights”
Page 5
And
“Reset the printer”
page 73 and 74
Or try a firmware update page 24
Some debris in the paper path, perhaps.
Let us know how it goes.
这个答案有帮助吗?
得分 2
2条评论:
Really because clearly he's not having a network issue is an issue with the printer brain that won't clear a false error. Network has nothing to do with it.
完成的
Thanks Cara.
完成的
添加一条评论
最有帮助的答案
Ignacio Vila there is not much in terms of factory (hard) reset for a printer. In the case of the HP Officejet Pro all you have to do is to :
Turn the printer on, if it is not already on.
Wait until the printer is idle and silent before you continue.
With the printer turned on, disconnect the power cord from the rear of the printer.
Unplug the power cord from the wall outlet.
Wait at least 60 seconds.
You can restore the printer to the original network settings. To restore the printer to the original network settings on the printer control panel, press and hold the Wireless button and the Cancel button together, approximately five seconds, and then release the buttons.
这个答案有帮助吗?
得分 3
7条评论:
Hi
Why have to unplug from the wall outlet?
完成的
where or what is the cancel button
完成的
Very unfortunate that HP cannot fix the problem of FALSE ERROR concerning Paper Jam.
(There is no paper jam but the Document Jam will not disappear).
For the HP 8720
Kindly explain:
“You can restore the printer to the original network settings. To restore the printer to the original network settings on the printer control panel, press and hold the Wireless button and the Cancel button together, approximately five seconds, and then release the buttons”.
完成的
Where are the wireless and cancel buttons
完成的
I believe the cancel button is the power button? The wireless button is the microphone with brackets around it?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Ignacio Vila 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 69
总计 89,595
