跳转到主内容
The Samsung RF28HFEDB is a 28 cu. ft. freestanding French door refrigerator featuring a twin cooling system, external ice and water dispenser, spill-proof shelves, gallon door bins, two humidity-controlled crispers, a bonus drawer, and an auto-defrost freezer with LED lighting.
3 个问题 查看全部
How do I fix the Pc Er code on Samsun Refrigerator model: RF28HFEDBSR?
I have already shut the fridge off and reconnected the main wire harness to the door several times. The Pc Er code keeps flashing. The previous owner had this fridge replaced because it was under warranty and sold it to me. Do I need to replace the control panel?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
8条评论
You did the correct procedure, but the company don't tell what to do it that fails. Maybe @ladytech knows.
完成的
@jmicbyerly try to clear the code by pressing power fridge & power freezer for 8 seconds
完成的
I tried pressing power fridge and power freezer but it didn't work. Thanks for the replies.
完成的
Have you tried simply unplugging the fridge for 60 seconds or so and plugging it back in?
完成的
Yes, I tried that, thank you.
完成的
显示更多的3条评论
添加一条评论
4个答案
已选择的解决方案
Removing the power from the appliance is not recommended for this error. The problem is usually a bad connection at the board. I have seen kinked communication tapes as well as damaged wires at the wire connections for the doors.
这个答案有帮助吗?
得分 3
11条评论:
Thanks. I replaced the main board and disconnected/reconnected the door connections with no change.
The led panel does not respond to any touch combinations but ice is being made and dispensed but no water dispensing. I was going to try a replacement of the dispensing control panel next?
完成的
John S. If the user interface isn’t responding and all the connection to it are good than there’s your problem. A failed user interface. If the communication tape to the board isn’t to expensive you might want to replace it also.
完成的
I have ordered the dispensing control board and will see if that solves this problem.
完成的
John S- Did you check to make sure the touch pad isn’t locked? There is a child lock button that you hold for 3 seconds that locks the controls so children can’t mess with the settings.
完成的
Yes, I did. None of the touch pad selections respond individually or in thr various combinations. My replacement should arrive on Monday.
完成的
显示更多的6条评论
添加一条评论
The error may be related to a communications problem between the display panel and the main board. Check the connections to ensure they are soundly connected. If this doesn't solve the error then you may want to call a service tech. likely need a new display panel
这个答案有帮助吗?
得分 1
添加一条评论
I had a similar problem and removing the ice maker reservoir in the door and replacing, reset my display. It has worked several times since.
这个答案有帮助吗?
得分 1
1条评论:
I just tried this and it worked! So odd.
完成的
添加一条评论
If you have replaced both boards, checked the connections and wiring then you probably need to replace the door. The wiring that is inside the door is the next most likely cause. This is expensive though so you may want to get a technician out to try to confirm it. You can try to measure the resistance of each wire from the top of the hinge to behind the door control panel but it may not tell you anything. Partial wire breaks are tough to track down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff Byerly 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 128
总计 16,577
