跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
20 个问题 查看全部
Replacement iPad Air screen spazzing
I’ve had my screen replaced 3 times not by Apple but due to the screen unsticking which I later found out that company bent my frame, It’s now started to spas out by itself so I can’t touch it or type anything. Does anyone know a fix before I buy a new iPad? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Ghost touch on Airs and Minis is due to the company not insulating the edges of the digitiser, so it shorts against the frame and causes touch to work by itself or cut out.
See this answer for details Digitizer activating itself after digitiser replacement
这个答案有帮助吗?
得分 3
添加一条评论
Take it to a more reputable repair place. Ghost touching on a screen is common with cheap screens. If you use a high quality screen, and high quality adhesive (along with good repair and frame cleaning practices), you will get a screen that doesn't lift and works like it should.
这个答案有帮助吗?
得分 1
1条评论:
The only problem is a it’s more expensive to replace than my iPad is actually worth, is there a cheap solution?
完成的
添加一条评论
添加你的答案
wlmsslsmskal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 307
