跳转到主内容
加入维修社区 - 创建账户
2001 年款 Dodge Caravan 和 2001 年款 Chrysler Town & Country 经过重新设计,于 2000 年 1 月 10 日在北美国际车展上首次亮相,并于 2000 年 8 月正式发售。
ignition key wont turn
turned off ignition and now key wont tun at all.How do I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
12条评论
i have done a few things sprayed with pb blaster then graphite powder to still see if this will work..........in the meantime bang it with something the key that is tap with hammer it worked for me today 3 out of 3 times the dealer wants 100 bucks just to do a diagnostic on it?
由完成的 分享
This works for me too! Thanks a lot!!!
由完成的 分享
There's a small pawl at the end of the lock cylinder that hangs up in the steering wheel lock. Pull off the plastic covers on the steering column and spray it with some kind of solvent. Hangs up because the old grease is cold or to stiff. Worked for me.
由完成的 分享
Mine did the same thing this morning. After completely melting down, I asked if we could disconnect the battery. Voila! It started and is running again. He said it looks like a loose connection in the battery cable.
由完成的 分享
I just sprayed wd 40 and tapped the key while in the ignition on an 05 caravan and after the 4th tap of the hammer the key turned perfectly..
由完成的 分享
显示更多的7条评论
添加一条评论
5个答案
已选择的解决方案
In addition to what Andrew said: The key or the lock may have broken or worn to the point of not working. Your dealer can make a factory key if given the VIN number.
这个答案有帮助吗?
得分 6
4条评论:
Omg thank you so much you just prevented me from having a freaking major panic attack!
由完成的 分享
Tap with a hammer works
由完成的 分享
Yella Gal How did you tap it, did you tap it in or sideways?
由完成的 分享
It work for for a couple days now it’s won’t turn at all.
由完成的 分享
添加一条评论
最有帮助的答案
Leave the key in the ignition and tap the end of it with something ( ice scraper works) I use a small hammer I keep in the console, the key will turn.
A locksmith showed me this, works everytime
这个答案有帮助吗?
得分 15
36条评论:
yes it does work but for how long and thank you for that by the way
由完成的 分享
This is a great idea in really work thanks wade
由完成的 分享
Wade . YOU DA MAN. And let us definately not forget to make a shout out to the Awesome locksmith that showed you that. Most are hoping you'll need to call them again , so they won't dare let you in on their secrets
由完成的 分享
Thanks!!! That was awesome. I had to have my van towed home and all I needed was a little hammer.
由完成的 分享
Thank you so much!! How long will this work?
由完成的 分享
显示更多的31条评论
添加一条评论
One other possible problem is foreign matter in the keyhole. If none of the other suggestions work, you might want to try blowing it out with compressed air. This is usually only problem for people with small children :-)
这个答案有帮助吗?
得分 3
添加一条评论
Sometimes rotating the steering wheel slightly back and forth while wiggling the key will make it turn. You could also try a different key if you have spares. It is improbable that any corrosion would form inside the ignition key cylinder, but places like NAPA make specific lock lubricants like this with graphite powder suspended in them to help free the pins in stubborn locks.
这个答案有帮助吗?
得分 2
1条评论:
Banging the key works because it dislodges the lock pawl on the switch. All of you need to pull off the steering column cover and clean the mechanism.
由完成的 分享
添加一条评论
Spray some WD40 in it . insert key few times . then take small hammer and tap key several times while wiggling . This will usually get it to turn . Then you need to replace lock cylinder before it does it to you again .
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tracym602 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 94
总计 61,495
