跳转到主内容
加入维修社区 - 创建账户
HP Pavilion g6-1b79dx 是一款 2011 年推出的 15.6 英寸笔记本电脑,采用锡灰色外观,内置摄像头并搭载 Intel Core i3 处理器。
Unable to delete 0 byte file.
I was playing with batch files and accidentaly created a 0 byte, no extention file.
I googled the problem and I found out that closing explorer.exe and deleting the file via command would help. Tried that. It didn't help. Any software that could do it? Any other suggestions?
Thanks for your help in advance :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Honestly, if its doing no harm to the laptop, you should probably just leave it.
由完成的
It's taking up space on my desktop. I need that space :(
由完成的
I would suggest using an administrative login to examine the file permissions. You need to open up the permissions and try the delete again afterwards. Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
由完成的
If its just taking up space on the desktop, you can set the file to be hidden so you cannot see it unless you have view hidden files enabled. also what is this File Unlocker thing mentioned in the file description?
由完成的
@professorc I doubt changing the permissions would do anything. Cygwin on the other hand might. I'll try that. Thanx for your help.
由完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
As I stated earlier.... Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Create a new profile in Windows with admin privileges.
Log out of the current profile.
Log into the new one.
Use explorer to go to your other profiles desktop location.
Manually delete that file.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your answer but explorer.exe simply does not see the file as... a file. Creating a new account would probably do thesame as killing explorer.exe and deleting the file via cmd which did not help as I said in the question. Thanks anyway.
由完成的
From the new profile open a new profile, open a command prompt with administrator privileages, and then use command prompt to navigate to where the 9 file is. Then "rmdir /s <file name> or del <file name>.
由完成的
添加一条评论
添加你的答案
SLimy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 895
