跳转到主内容
加入维修社区 - 创建账户
Roomba 650 是 iRobot 于 2012 年 8 月发布的一款第四代扫地机器人。该设备无需动手,可通过编程实现自动清扫居家环境。它几乎不需要手动操作,彻底改变了家庭清洁方式。
Error 5 iRobot roomba 650
I have replaced the battery with the new one and still after charging it says please charge the roomba
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Error 5 indicates a battery problem
Try this link and see if this will help
https://homesupport.irobot.com/app/answe...
这个答案有帮助吗?
得分 1
添加一条评论
xkubasj: The reason is that this charger has different parameters than the original one. Although the original power supply has nominal output voltage 22.5 V, the voltage drops to approx. 19.1V under 1A load. This third-party adaptor however holds nominal voltage 22.5V which leads to increased charging current about 3A. Roomba's charge controller than switches to fail-safe mode.
这个答案有帮助吗?
得分 1
添加一条评论
Here is a good step by step:
https://yoursmarthomeguide.com/smart-app...
这个答案有帮助吗?
得分 0
添加一条评论
Did you get genuine iRobot battery? Otherwise, suggest to check steps mentioned here (cleaning contacts, etc.): https://homesupport.irobot.com/app/answe...
这个答案有帮助吗?
得分 0
2条评论:
@robotechy good answer but it has an identical link as the answer from a year ago. So yours does not add anything new to this as a solution. Maybe you can narrow it down and/or be more specific about the error itself
由完成的
Interesting comments have a https://www.vacuumkoo.com/roomba-860-vs-... the different between the battery one has had this error message and the it look like iRobot mentioned regarding the type of battery used.
由完成的
添加一条评论
添加你的答案
azornic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 14,906
