跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Upgrade HDD to SSD and use PCIe as second hard drive?
Hi,
I have a late 2014 Mac Mini with the 1.12TB fusion drive. Can I replace the mechanical HDD with an SSD and still use the PCIe SSD as a second hard drive?
Or will the system attempt to create a fusion drive using the two ssd drives?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you currently have a Fusion Drive setup (have the PCIe SSD installed as well) you'll first need to break it to switch out the HD for the SSD. You won't be able to re-create the Fusion Drive setup with two SSD's in the system. Here's how thats done: How to split up a Fusion Drive
Here's the IFIXIT guide you'll want to follow to swap out your HD for a SSD: Mac Mini Late 2014 Hard Drive Replacement.
While you don't need to setup a bootable OS installer to install the OS as this system supports Internet Recovery it will be faster setting up a bootable USB thumb drive as an OS installer. Or get this: Startech 2.5" SATA to USB adapter which will allow you to prep the SSD using your current HD. Here is a good reference on the startup commands: Startup key combinations for Mac.
Just take your time and don't force things! Be careful in disconnecting the cables as some of the small SMT components can be damaged or pulled off if you don't use care.
Many people get confused on what they are buying. So I just wanted to cover that issue in case you had that model. When you open the system if you see this then you have a PCIe SSD in your system. If you don't you're good!
As to using a SATA SSD in this system we have upgraded quite a few with no issues! Its just a plug & play situation. No other hardware alterations are needed.
The only rub is setting up the OS after installing. That was the major point in what I spoke about here. You have a few different ways to do it and you might need to consider which way you go.
Update (01/16/2017)
OK, then you do have a Fusion Drive!
So follow My first point as you'll need to break the fusion set before you alter the drives. Once thats done you'll see two discreet drives the (HD & SSD that make up the fusion set). Then you can replace your HD for a second SSD.
If you where thinking of re-joining the two drives (SSD & SSD) into a Fusion Drive you just won't gain any benefit and just confuse the poor system on which is the SSD as both are!
You also seem to be confused on what your storage will be (size wise). As you are taking the HD out you will only have the custom blade SSD left in the system which is only 256 GB in size (the HD is 750 GB on the 1 TB Fusion Drive).
So your re-configured system will be 256 GB + 512 GB for a total of 768 GB so your total storage will be less!
If you where thinking of swapping out the custom blade SSD then the Samsung EVO SSD is not the correct drive! Sadly, there is no 3rd party offering you will need to locate an Apple spare (very expensive) or a used unit off of eBay.
So in a nutshell I don't think this is a wise direction for you. I think an external Thunderbolt RAID'ed SSD set would give you the speed I think you are looking for and is a lot easier to deal with.
这个答案有帮助吗?
得分 3
5条评论:
Ok so this answer is the chosen answer from this post: Upgrade 1TB HD to Samsung 850 EVO 500GB (MZ-75E500BW)
I did not come up with any of that, our colleague @oldturkey03 did, so there's that :))
完成的
@alexniculescu I was just about to write you what a great answer this was . And it is. But @danj wrote it. But you get an up vote from me for finding it and giving credit to the author ;-)
完成的
@mayer hey if @danj comes and reposts it under his name I'll gladly delete mine
完成的
@alexniculescu - Make sure the answer you use is the correct one for the given question! I don't mind being plagiarized if it's the right answer & given credit ;-}
You can go into edit mode and alter things.
完成的
@alexniculescu There is no harm in finding a great answer, go right ahead. If truth be told almost every question we answer here has been answered by someone before. It is polite to give the original author an up vote and credit on your answer (like you did). When we do, get in an original question, I may spend hours researching it and give a very comprehensive answer. By the time I've answered the same question for the tenth time. It may get reduced to something like, " replace the doohickey", with no explanation.
完成的
添加一条评论
添加你的答案
Joseph Coupe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,885
