跳转到主内容
加入维修社区 - 创建账户
Apple Watch Series 2,于 2016 年 9 月 7 日发布,并于 2016 年 9 月 16 日上市。
Apple Watch Series 3 screen replacement
Hello people from ifixit,
I need to know if the complete screen from Apple Watch Series 3 is the same as Series 2 and can be replace one for the other or need to remove some flex or IC from one to put in the other. Some people tell me that need to change the NFC IC.
Thank you
Update (10/30/2017)
Hello Dan, and thank you for you're quickly answer.
Really what I need is a technical opinion and not about warranty coverage because I have many Series 2 from many customers with crack screens that need to be replaced.
But no one has big quantity of Series 2 complete screen on the market to buy. For this reason I posted the question. My supplier in China who I did buy many Series 1 complete screens (hyper-trustable) tell me that the LCD & Touchscreen module is compatible.
But, need to replace a flat ribbon cable with some component that are glued on the back side of this module, they call it the NFC IC but I don't know really if is trueIy inclusive in the Series 3 teardown description the IFIXIT team wrote this info: "Spec-wise, the display is unchanged from the Series 2, with one key difference - it now functions as a multifrequency (LTE?) antenna. We'll be testing compatibility to see if the displays really are interchangeable."
Based in this info I believe that both are compatible.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
@quekilombo I would recommend you watch this YouTube Vid: Apple Watch Series 3 Teardown and Comparison! (GPS vs LTE) Alex goes over the screen a bit.
由完成的
I did watch but dont say nothing about compatibility
由完成的
An Apple Watch Series 1/2 screen is different than the Series 3 by part number. I don't believe you can substitute one for the other.
由完成的
What are you basing this on ? Obviously apple part number is different cant see the local Apple authorised repairer transferring the NFC onto a series 2 lcd . This is the Aftermarket we do what is possible. Im also currently researching this also and about to trial it.
由完成的
hello!, I have an Apple Watch series 3 with a broken screen. my touchscreen doesn't work anymore on one side. is that because of the broken screen? is it better for me to only replace the glass or also the display
由完成的
显示更多的1条评论
添加一条评论
10个答案
已选择的解决方案
I don't think anyone has even thought about doing this... The AW3's screen is brighter than the AW2's!
As the AW3 is so new you should try to get it covered under warranty (get AppleCare + if you don't already).
Update (01/31/2018)
@quekilombo - Diego - The NFC unit is missing on the Series 3 display so you would need to recover the chip from the broken Series 2 display if you could to then re-solder onto the new display to get this to work. Given the sensitivity of the LCD unit and the mass of the glass this will be very difficult to do without damaging the display. Here's the back side so you can see the difference:
Series 2
Series 3
The Blue outline is the NFC chip and the spot on the Series 3 is vacant. I think I understand why Apple did this as replacing a broken display would invalidate the information in the watch when people had ApplePay enabled. Having it as part of the main board makes sense.
这个答案有帮助吗?
得分 3
添加一条评论
Just replaced a screen on a series 3 LTE. I used a donor screen from a locked Series 3 LTE. Everything went off without a hitch. However, I can confirm Apple pay does not work. I get an error when attempting to set it up. I have not yet attempted to swap the NFC chip. I will attempt to see if I can remove the NFC chip tomorrow from the cracked screen and install... If anyone has any further information about this I would be happy to hear it...
这个答案有帮助吗?
得分 2
13条评论:
Were you able to swap the NFC and restore Apple Pay?
由完成的
This is different than what Diego is trying to do.
由完成的
Yea I know Dan, but Jesse has done what I am trying to do for a customer. Haven’t taken on the repair yet, and want to have all the info before taking it on
由完成的
You mean Jessa Jones of iPad rehab?
由完成的
Can you seriously not read the post I responded to where Jesse replaced a cracked AW3 LTE screen with a good screen from a different AW3 LTE and had a problem with Apple Pay?
由完成的
显示更多的8条评论
添加一条评论
Hi, I have the same problem, It looks that no one is selling digitizers for series 2 at the moment...
I have series 3 complete screen so I test it wit series 2 watch and see if it works.
这个答案有帮助吗?
得分 1
2条评论:
Have you tested the LCD? Does everything work?
Do you have an Apple Watch 3 LTE w/GPS? And put on the LCD form an Apple Watch 2?
由完成的
Did it work? is it a S3 GPS or LTE?
由完成的
添加一条评论
I have successfully swapped a S2 Display onto a S3 Watch.
I removed the Light Sensor / NFC Module from the damaged S3 Display and attached it to a working S2 Display. I used conductive ink to make electrical connection to the two antenna points under the module, and superglue to mechanically attach the Module. Next I reflashed the Watch firmware using a (non-Apple) hardware device similar to the one used at the Apple Genius Bar.
I verified NFC functionality by setting up Apple Pay on the Watch, double-tapping the Side Button to activate Apple Pay as though I were about to make a purchase, and reading the "tag" data with an app called "CardTest" on an Android phone.
The repair is a little bit fiddly but doable.
这个答案有帮助吗?
得分 1
3条评论:
Is there a video or walkthrough for this procedure?
由完成的
Was it necessary to reflash the Watch because it was a series 2 screen? Would you have to do this to a series 3 as well if you were changing the NFC?
由完成的
Hi Gordon! Do you know if the swap of the NFC part is possible on the Series 4 watch as well? Is it necessary to reflash the firmware for normal use of apple pay after the swap? Thanks!
由完成的
添加一条评论
Hi
I have recently changed my broken lte series 3 watch with a series 3 gps watch. The force touch was not damaged. The Apple Pay won’t work, was it confirmed that the chip was on the old lcd? If not is there a way of getting it to work again?
这个答案有帮助吗?
得分 1
13条评论:
See my post above; it looks like you have to preserve the NFC/Light Sensor module from the original display. I think this is probably a similar situation to how the TouchID sensor is tied to a specific mainboard in iPhones.
I used a #17 xacto blade to remove the modules. If you're careful you can do this without damaging the display. You'll need a conductive adhesive to make the antenna connections between the module from the broken display and the new display. That way you don't have to worry about damaging the OLED with heat from soldering. Just use two tiny dots of conductive adhesive so they don't short out to each other. Then use superglue for strength.
由完成的
Cheers Gordon. This does not sound easy. Any idea if someone has put this on YouTube? I’m torn as to try and fix it and risk wasting a good screen or just keep it but don’t use Apple Pay. Thanks for your help.
由完成的
Also, does anyone have a good recommendation for the adhesive gasket as I used one for series 1 & 2 but when putting it in I found it to be slightly smaller than the touch force meaning the seal was not as strong as I would like.
由完成的
Unfortunately I can't make a video. But it's not too difficult, other than requiring precision placement. For sealing the watch back up I used a 1mm tape for mounting tablet displays. Put the tape on the display and overlap the corners very slightly. Where I work we have a wet pressure testing chamber; I took a watch case and attached just a bare glass (no OLED or digi) to it with 1mm tape -- this way I could look into the watch without disassembling it. I put it in the pressure chamber and ran it down to 100 feet depth. After an hour there was one drop of water inside.
We did try using precut adhesive for mounting displays. Most vendors selling the precut adhesive use 3M 300LSE adhesive. We had a lot of returns for displays coming off; this 3M adhesive is not strong enough. So we switched to the 1mm tape. You just have to be super careful at the corners. If you overlap too much the force touch gets weird because it doesn't like the lumps. If you don't overlap enough it will leak at the corners.
由完成的
Thanks again Gordon, your knowledge is appreciated. Can I trouble you for a little more info....
1. Have you got a brand recommendation for the 1mm tape? As I have found a few online but it would be great to have one that others use and recommend
2. Do you have any pictures or diagrams to assist with removing and preserving the ncf/light sensor? Only asking as I would not feel confident doing this without see what should be done.
Cheers
由完成的
显示更多的8条评论
添加一条评论
此回答最初是针对另一个问题。
I see here that nobody had the idea to remove entire NFS module. Its just glued on the back of AMOLED. Just use 100ºC from some distance with air station. Just remove from s3 and put on s2 lcd (or vice versa). Job done.
We can see 3 connectors.
1- first one is the LCD (same)
2- touch (exact the same in s2 and s3! just see the IC - its same IC in both models). Touch screen for s2 is the same for s3!
3- third module has some differences but can be easily removed and replaced.
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题。
I cannot find an answer for this, there is no guide and iFixit does not even stock them, I wouldn't take the risk if I were you. If memory serves, they are different because the cellular model uses the screen as an antenna for the cellular (I think). A non cellular model might work. Maybe. Repair is quite difficult on these models as well, so all I can tell you is good luck.
这个答案有帮助吗?
得分 0
添加一条评论
No Watch 3 LTE in SA we did not get this function if it has LTE there is a red dot on the turning know
这个答案有帮助吗?
得分 0
2条评论:
Knob button I meant
由完成的
Only the LTE watch has the Red dot.
由完成的
添加一条评论
Can a Series 1 LCD be put on Series 3 (GPS + Cellular)
这个答案有帮助吗?
得分 0
1条评论:
No they're not interchangeable.
由完成的
添加一条评论
此回答最初是针对另一个问题。
hello, i just tried this on a 42mm and it does not work you will need a series 2 screen
这个答案有帮助吗?
得分 0
1条评论:
You used a S3 GPS or S3 LTE? I read S2 and S3 GPS are interchangeable.
由完成的
添加一条评论
添加你的答案
Diego E. Rojkis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 33
总计 38,416
