跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why does my phone randomly shut off?
Yesterday, I installed a replacement battery in my iPhone 4S. The charge icon indicates that the battery is 100% charged. I removed the phone from the charger and left it on for 24 hours and it still shows a 100% charge. But, it has randomly shut off 3-4 times. Each time, I have to plug the charger back in before the phone will boot. There are no "low battery" warnings and the screen always shows the battery at 100%.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Greg!
I understand you purchased a new battery from iFixit! Thanks for your order! Sorry to hear you're encountering trouble after your repairs.
If I may ask, what was the reason for your repairs, and was this issue occurring with the previously installed battery? If you're able to reinstall the older battery and not encounter this same issue, then I'd suggest contacting our Customer Support team through this Help page here.
They'll be able to either offer additional troubleshooting steps to see if they can get that battery working correctly, or get a replacement out to you.
这个答案有帮助吗?
得分 1
1条评论:
Hi,
The original battery was not holding a charge any longer. I was lucky to get 3 hours out of it before I needed to plug in the charger. I assumed that the battery was just worn out. The battery monitor seemed to provide an accurate estimate of battery drain, but every now and then, the monitor would instantly go from around 50% to 0%. So, I bought a new battery. It seemed to work for the first 12-18 hours (I was trying to drain it as per the installation instructions). But the battery monitor never displayed anything but 100%. Unfortunately, I disposed of the old battery before I encountered this problem.
Thanks for your help.
Greg
完成的
添加一条评论
最有帮助的答案
@gmorris this "I have to plug the charger back in before the phone will boot." as well as the battery always showing 100% would lead me to suggest that you start with a new battery. Here is the guide for it iPhone4s 电池更换 and a new battery is available right here iPhone 4S Battery
If nothing else it will give you a known-good starting point for further troubleshooting if necessary
iPhone 4S Battery图片
产品
iPhone 4S Battery
$16.99
这个答案有帮助吗?
得分 2
1条评论:
I installed a new battery that I purchased from ifixit.
完成的
添加一条评论
添加你的答案
Greg Morris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 119
