跳转到主内容
The Lenovo IdeaPad 300-17ISK is a 17-inch laptop which was released in October 2016. The Model number is 80QH008MUS.
Fan Replacement without heatsink
Hi There, I was wondering if there will be any issues replacing the fan with one of same size but no (what I believe to be) heat sink? Whatever the Copper attachment is. The fan bearing went bad so now it shakes and makes a lot of noise when I use my laptop which is quite annoying, I deal with it by using headphones but can't really take it out because of how loud it is. If I can't replace the fan with aftermarket fans that don't have the copper attachment is there anywhere I can purchase the same fan used for this laptop?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Here is a link to the service manual for your IdeaPad.
Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove the fan/heatsink assembly.
Scroll to p.87 to view the parts numbers (#12&13) for the fan and heat sink. Search online using the appropriate part number only to find suppliers of the part that suit you.
这个答案有帮助吗?
得分 2
添加一条评论
this is what you need. https://www.ebay.co.uk/i/192312127707?ch...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kevin Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 546
