跳转到主内容
US models went on sale as a 2012 model year vehicle. Early models include a choice of four-door sedan or five-door hatchback body, 2.0-liter DOHC (148 hp) engine, five-speed manual or Lineartronic CVT with paddle shifting six-speed manual mode.
Key will not release
2013 Subaru Impreza
Key will not release when we shut the engine off. We have already troubleshot several steps. Brake is applied, transmission firmly in park, pushing key inward while turning engine off. Engine shuts off but will not complete cycle so that it can be removed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Hi don, is the steering wheel locked? Make sure that is can turn a full 360.
完成的
添加一条评论
3个答案
If it has a locking steering column, the wheel may be turned too far. Turn the key while jerking the steering wheel back and forth fractionally.
这个答案有帮助吗?
得分 0
添加一条评论
Included with the above recommendations, I depress the brake pedal while removing the key. This might help.
这个答案有帮助吗?
得分 0
添加一条评论
I had this issue with my 2016 Impreza. After pulling apart the center console, I figured out what was causing my issue.
To move the shift knob the driver needs to squeeze in the button on the front (blue circle in the picture). This lifts up a rod through the knob (red line in picture) . with the rod up the shift knob can be moved into gear. The rod also presses a button when in park, releasing the key. My issues was the rod was not dropping all the way down and activating the switch. I pulled the rod out and put some light grease on it, hasn’t been a problem since. It was not to much work to get the rod out but I don’t remember exactly how.
Sorry its so late, maybe this will help someone else
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
don fagan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 6,121
