跳转到主内容
加入维修社区 - 创建账户
SONOS PLAY 5 是最初的一款适用于较大房间、拥有更大音效的 Sonos 一体化音乐播放器。
High voltage fuse blowing immediately
Hi,
My Sonos Play 5 (Gen 1) is blowing the internal high voltage fuse immediately when i'm turning the power on. Anybody who can assist with a schematic of the PCB or any who have seen this kind of problem before?
For info, I'm currently sitting on the northsea on a olieplatform and there is a bit lack of spare parts. But i have the most standards parts.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
13条评论
@laversen disassemble it and post some images of the boards with your question. That would allow us to see what you see and maybe even see something abnormal. Use this guide or that 在已经存在的问题里加入图片
由完成的
@oldturkey03, The post have been updated.
由完成的
Is the repair has been successful? What was damaged ?
I have the some problem
Fuse blown
I look on the diode bridge , but shorts is on the pcb d27718 pin 1 to 3. No shorts on the diode.
Thanks for any help.
由完成的
Same problem! But were can I find the fuse?
由完成的
Hi @ ceeskoedijk,
Do you mean where is the fuse located on the board?
If you look at the image posted above the glass fuse is on the board just above the power input socket.
If you mean what value is the fuse and where do you get it?
Remove the fuse and check what is stamped on the metal ends. There will be a Voltage (V) and Current (A) rating and if it has a T (indicates slow blow)
Also measure the length and diameter of the fuse cartridge
Once you have all the information search online for a (insert values ) fuse to get results and then check for one that has those values with the correct physical size.
由完成的
显示更多的8条评论
添加一条评论
1个答案
已选择的解决方案
It sounds like a problem in the power supply section. An electrolytic capacitor with a domed top or showing signs of leakage will hopefully give you a quick win, but otherwise my guess would be the rectifier or switching transistor on the high voltage side.
这个答案有帮助吗?
得分 2
2条评论:
Also what i was looking into at first.
At first I changed the big capacitors, no help. After i wrote the post yesterday I have changed the diode bridge, it's was shorted, now the fuse don't blow. But it still dosen't shows any signs of life.
由完成的
Next would be the switching transistor on a heatsink just south of the transformer in your photo. There's also an 8-pin IC down that way, and if you can identify and replace that it'd be worth doing. And I can see 6 surface mount transistors. These will have abbreviated type codes. If you can identify them as junction transistors you can test them (more or less) in situ with the diode range of a multimeter, and whatever they are, a short between any 2 terminals would point to trouble.
I had a glance at Google for schematics but found nothing. Sometimes you can have more success with yandex.ru or baidu.com though a quick look didn't come up with anything.
Hey, if you're on an oil platform I'd guess that a power surge created by some heavy electrical machinery might be what has done the damage.
由完成的
添加一条评论
添加你的答案
Peter Lauridsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 6,847
