跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
No volume control- headphones or dock
I can't control the volume output of my 1st gen Touch on firmware 3.3.1.
When I plug headphones in the volume slider doesn't appear, reading around I see this was a pretty common issue when people updated to 3.x so I ran a jailbreak and installed SBSettings and the volume slider widget - it doesn't control the volume, still stays at a constant level.
I plugged into the dock and have the same issue - no control over volume from the iPod.
So although I was initially thinking a headphone jack might need replaced I'm not so sure now that when docked it still has the same issue!
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Just realised you can't control the volume in a dock with the volume slider on any iPod - maybe it is tahat jack needing replaced!
完成的
添加一条评论
1个答案
已选择的解决方案
I would definitely start with the headphone jack. It is solder on the logic board and is available here http://www.parts4ipods.com/epages/es1157... and here http://www.ipadpartsshop.com/product_inf... and the instructions for the logic board are here iPod Touch 1st Generation Logic Board Replacement Good Luck to you and let us know what worked. :-)
这个答案有帮助吗?
得分 1
2条评论:
Replacing the jack indeed did work - I just removed the ribbon and soldered small jumper cables.
完成的
Congratulations, good job and inventive :-) Thanks for accepting my answer.
完成的
添加一条评论
添加你的答案
Neil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 3,766
