跳转到主内容
The JBL Charge 2+ made by JBL is the second generation of the JBL Charge brand.
20 个问题 查看全部
No sound only while playing music, Auxiliary connection works
I've been facing no sound issue only on Bluetooth connection while playing music, it works fine for calls and auxiliary connection. I've tried doing a power drain and recharged my device, also tried a reset however still can't play music through Bluetooth. I also connected the speaker to a different phone however the problem is still there.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi @talhatahir ,
Assuming that you can BT pair the speaker successfully, does it work on BT if you have the charger connected (and switched on) to the speaker?
完成的
No, it doesn't unfortunately.
I am able to make calls through the speaker it's just the music that doesn't play through BT.
完成的
I would try resetting (power cycling) your bluetooth device and the JBL. Unpair the JBL and re-pair the Bluetooth connection. This works with a lot of bluetooth devices.
完成的
I did that already however it didn't help in resolving the issue.
完成的
添加一条评论
2个答案
最有帮助的答案
Someone in the comments (Daniel Rall) seems to have the same problem: https://forums.androidcentral.com/androi...
Will it start playing music and then stop, or does it just not work at all?
Here's another thread of a similar issue, but with a computer and a different speaker (not sure how relevant): https://superuser.com/questions/1024006/...
You might explore your phone's settings to see if there's a music vs call setting. If the other phone you tried was an Android, it might be a new update. Otherwise, maybe open the speaker to look for damage if it's not still under warranty.
这个答案有帮助吗?
得分 1
1条评论:
This is not my issue, there is no issue from the phone. I am not able to find a thread I came across two days ago where it showed a problem with a capacitor or some other small piece of hardware that needs to be replaced, there was a video link top however the language was Russian I guess hence I couldn't understand the fix.
完成的
添加一条评论
some phone need to open the Bluetooth settings & enable "music" instead of only "calls" in the particular paired Bluetooth audio device...mine was honor 8 & had same issue when trying to pair to car audio via Bluetooth
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Talha Tahir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,984
