跳转到主内容
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
80 个问题 查看全部
My furby just quit moving
My furby just quit moving and his eyes want to stay shut .so i put a piece of paper in 1 eye lid to keep them open. Verbally he is ok .just NO MOVEMENT AT ALL..what can i do to fix?.is there an fix it shop for furny? So i can get him fixed ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
The small 6V brushless DC motor went wrong. I had the same issue. You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good. You need a solder iron as well to replace electronic part from DC motor.
这个答案有帮助吗?
得分 1
2条评论:
There is a PCB Board at the back of the furby that controls the movements and it could be damaged or corrupted. 2 of my furbies have this problem and is there any way that this problem can be troubleshot. If so, let me know
完成的
@Oliver Soanes You could try to clean the board with rubbing alcohol, this helps as it cleans up any debris along the way.
完成的
添加一条评论
最有帮助的答案
gaylee marie check the Light sensor photocell in Furby's forehead. I would start on that one and see if it is still functioning. For way more info on the Furby, check this site. It has great information and plenty of autopsy pics. Attached is the diagram for the Furby's electronics. check it out and see if that will help to bring Furby back. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
3条评论:
@oldturkey03 where did you find the anatomy of a furby? :-)
完成的
@avanteguarde years of collecting ;-)
完成的
@oldturkey03 I wonder if you have enough information to reprogram to be a time traveling furby with the voice of a certain Austrian movie star sent to protect us from the future.
完成的
添加一条评论
Motor problem for this issue
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
gaylee marie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,493
