跳转到主内容
加入维修社区 - 创建账户
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月16号作为iPad Mini Retina屏版本(现在也称作iPad mini 2)的新一代被发布。
Why no display ipad mini 3
ipad mini 3 touch screen, home button and lcd replacement. After put it together again apple logo shows up for 1-2 seconds than black screen (voice everything you can hear pc as well recognise the ipad.Touch screen work you can hear the games open after touch) just no display. What else I should do I have tried the hard reset even recovery but no successful. When turn off and turn on again apple logo show up for about one- two seconds than black.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Did you disconnect the battery before removing and installing the LCD (see step 42 of this guide)? Not disconnecting the battery can cause backlight circuit damage. This would require a micro-soldering repair.
It is also possible that the LCD is defective. Depending on how damaged your original LCD was, you could always try to put it back to see if it "works" like it did before the repair.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ula 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 23
总计 708
