跳转到主内容
加入维修社区 - 创建账户
2017 年 9 月 22 日发布。型号 A1864、A1897。有 GSM 或 CDMA 版本可选,存储空间为 64 GB 或 256 GB,颜色有金色、银色和深空灰色。
iPhone 8+ and iPhone 7+ lcd
iPhone 8+ display compatibility and iPhone 7+?in Ches the difference
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
最有帮助的答案
Here's the latest info on the iPhone 8:
iPhone 8 拆解
这个答案有帮助吗?
得分 3
添加一条评论
Both of them can't work well on each other. I write an article "What’s the difference between iPhone 8 and iPhone 7 LCD screen?", if you want to see it please see my profile then visit my blog. Also you can watch the video here:https://youtu.be/KxFovnbcY3E
这个答案有帮助吗?
得分 1
添加一条评论
Be VERY AWARE of chinese sellers on eBay trying to pass off iPhone 7 Plus screens for iPhone 8 Plus. They nearly look identical.
这个答案有帮助吗?
得分 1
1条评论:
7 has hooks at the top and 8 has metal brackets
由完成的
添加一条评论
They looks similar but they can't work well on each other or say it not full functioning on each other,
这个答案有帮助吗?
得分 1
添加一条评论
No, you wouldn't be able to interchange displays between generations of iPhones. The 8 uses a 3 channel, temperature sensitive light sensor.
The 7 uses a single channel, light only sensitive sensor.
The ribbon cables are also likely different.
这个答案有帮助吗?
得分 0
添加一条评论
Yes you can put the iPhone 8 + digitizer on a 7+ iPhone.
And it will work just fine, only the display.
You need to use the orignal homebutton and sensor/frontcam cable.
The screws in the bottom wont fit unfortuanately
这个答案有帮助吗?
得分 0
1条评论:
It can work but will have issues
由完成的
添加一条评论
添加你的答案
Alex Pro 将永远感激不已
浏览统计数据:
过去 24 小时: 25
过去 7 天: 43
过去 30 天: 53
总计 5,436
