跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Why did it die?
Here's the details... no hidden occurrences,
I purchased a 2015 MacBook 12" Retina for a trip to Asia. I was traveling extensively via Plane, Train and Boat so I wanted something compact.
It arrived used from eBay, but working perfectly.
I was in and around China for 1 month and had absolutely zero issues with the unit.
I arrived back in the states and still, zero issues.
I was leaving for NY for a few days and placed the MacBook on my kitchen table, plugged in to charge.
After arriving home I unplugged the unit and attempted to turn it on and nothing. No bleeps, bings or flashes... absolutely nothing.
I believed it may have been improperly plugged in so I left it to charge again... nothing. Changed charger and cord... nothing.
Something was obviously wrong and all Apple Support Documents say remove the battery. So, I opened the unit and displaced the battery from the logic board. No luck.
I replaced the KeyBoard Ribbon Cable, USB-C Port and even a new Battery... nothing.
So my question is, what happened? How does a unit go bad just sitting on a kitchen table?
Before any rants - I live alone, so no my kids didn't spill anything on it nor did anyone touch it while I was away. I tried all the SMC and PRAM reset methods too. Nothing works.
Please Help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Same here, exactly the same issue and same procedure, no luck too.
Anyone more?
I'm going to send it to Apple to see what happen, if it's expensive I will start to think in move all my devices to another brand.
完成的
添加一条评论
2个答案
最有帮助的答案
This has happened to me as well. What you can do is replace the DC in power adapter (this is an internal circuit board) and you can order it from eBay for about 10 bucks.
这个答案有帮助吗?
得分 2
4条评论:
what do I search for on eBay? Are there instructions on how to replace the DC in power adapter?
完成的
hello i need a help please did happen me the same problem but instead of your situation me was screen replacement my macbook now is dead ,please what is the name this part with more clarification thank you for helps me .
完成的
Dam! I wish this was posted sooner. It sounds like the right solution, but I listed the unit on eBay as busted and it already has bids.
Thanks, but there comes a point when you spend so much on replacement parts that don't work... you need to cut your losses and that's where I was when I listed it last night.
完成的
@brahim saidi, Is it really dead? Plug in an external monitor and test it. It might ne the LCD only,
完成的
添加一条评论
same happened to mine, just got a used logic board and it works again, apparently these laptops have a reputation with bad logic boards. I lost all my data in the process. good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sjdan13ls 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 859
